TwinTurbo.NET: Nissan 300ZX forum - More pressure drop at the same driving pressure means >
Subject More pressure drop at the same driving pressure means >
Posted by my91z on June 26, 2003 at 9:16 AM
  This message has been viewed 51 times.
In Reply To The length of the core does not contribute to the flow rate. posted by sparkie on June 26, 2003 at 09:08 AM
Message less cfm through the heat exchanger.
AFAIK a turbo or SC is a constant volume device at a given rpm, not a constant pressure device. Since the air will compress in front of the more restrictive heat exchanger you will get a reduced flow rate through it.
You are saying that you can blow the same amount of air through a 1" section of McDonalds straw as you can through a 10 foot length of the same cross section straw. This is not correct.
Mike
Click here to e-mail me!
